Help with GBCoid on Tablet
Hi,
I found several threads on GBCoid in this forum, but I couldn't find one that addressed this problem, so I hope this post is okay.
I downloaded GBCoid from Sourceforge (because it isn't available in the play store) to my Nexus 7 tablet. Upon install I have the option to run the game and it runs fine. However, GBCoid doesn't install an icon for my tablet's desktop, or if it does, I don't know where it is.
The only way I can play it is to use a File Manager to look through my downloads folder and re-install it every time I want to play. (I can't find the folder where GBCoid installs through a file manager, either.)
Has anyone else had this problem on their Android tablets? Could you help me?
Thank you in advance for your time.
You should be able to find it under "Apps", which lists everything you've got installed. Hold your finger on it for a few seconds, the desktop/home-screen should appear, release finger and viola!
