help with Gmote
I can't remember my password for gmote haha. Haven't used it in so long i guess. And now i can't access the servers. I uninstalled the app and unistalled the program on my computer and even after redownloading the program/app, it still remember all my settings and what not, therefore i still need to know my password. I just want to start over and re do everything or find a better app?
Any ideas?
Thanks
Any ideas?
Thanks
Have you tried renaming your Computer? If you have XP right click my computer and go to properties. Under the "Computer Name" tab try renaming it to something else.
I use media monkey on my computer (Great way to sync to the Droid, btw), and I try to use gmote to control my music when media monkey plays it. But it doesn't work. Does gmote only work with its own media player?
Any ideas?
Thanks
More than likely its in your documents and settings for that user. Create a new user account in Windows and try and see if that works. That should do the trick.
