Help with Go Locker please
ESmits
Basically i'm trying to customize my Evo 3D and my next step is a better lock screen. I've finally got one from Go Locker that says security is possible.
However, i cannot get it to work :L. I'm left with a simple slide to unlock that has no security, no pattern or even a pin, despite one being set. The only way to get it working is to revert back to the HTC sense lock screen.
Any ideas?
Different themes are there for Go locker. I think there is no option to set a password or a pattern to unlock. Widget locker also have this issue.
I use Go Locker and there is a way to set a security pin/pattern:
On your homescreen press Menu>Preferences>Visual Settings>Go Locker>Security
Here you may choose either pattern or pin lock.. At least this is how I do it on my phone. Works well too..
There are also lots of different themes for Go Locker which you can search for in the Market or Go Store..
Thanks, i managed to fix the issue in the end by doing this, and using No Lock to hide the original lock screen and avoid the double lock.
