Help Help with GUI-issue?
Hi!
I'm new here in Android Forum, and joined because I really need help. Yesterday I left my HTC Legend to my 4-yrs-old and he managed to twist the gui from the 7-screens I am used to, to some 3-screens variety with a sort-of-upside-down-drop in the bottom.
I can't find where I get my usual screens back! Can anyone help me? I google and don't find anything, probably I don't use the right words. I feel a bit stupid here...
Please help me!
/Anna
You can try to Hard-reset the phone.. Should bring everything back to normal.
But this will also delete all your contacts/sms/files/apps.. So make sure you got at least your contact backup before you do it :)
No do not hard reset. I think he set the default home to stock. What you should do is
1. on the home screen, press hardware home button
2. if there is a popup asking what would you like to open this with, skip to step 4. else, go to step 3.
3. go to settings -> applications -> manage applications -> find the application called "Home" and then press "clear defaults"
Now click the hardware home button and
4. press "HTC sense" and tick "set as default"
