Help Help with Home Sceen
whitlow
So my home screen changed what can I do to fix it? when I tap home it goes to a different screen than it use to. I went into edit and tried to move them around to get the screen I had back to home but did not work. I have a icon on the bottom of one of the screens while in edit that looks like the home button and it stays on that screen no matter what I do. I moved that screen everywhere to far left to far right but it still stays as my home screen. I want my old home screen back Help me please.
I hope I have explained this correctly.....
What number is at the top of the screen, Samsung launcher will always use screen number 1 as the home screen.
Other launchers can be set to use a different screen as "Home", but unless you have installed a new launcher you should be on screen 1.
Go to the Market and look for Home Switcher (if you are on Froyo look for Home Switcher for Froyo). Install it and see if you have multiple launcher, you can also switch between them.
