Help Help with HTC home screen panel layout
lrxo
Okay so earlier today I got the HTC desire 610 and have been setting up and using it fine all day. About an hour ago I was on the blinkfeed panel and as I went to swipe to my home screen panel and I realised it wouldn't fully swipe (still showing some blinkfeed screen) then I noticed my weather clock widgets time was overlapping the date and weather. Now ive cleared all panels but it seems every app/widget I add to my home screen doesn't show properly as though its squashed and there isn't enough space for the whole icon, although it shows normally when arranging the apps/widgets around the panel when actually on the panel itself not all of the apps show properly also the swiping issue is still there.. please help!
Moved to your proper support forum the HTC Desire 610, you should be able to get better help and support here, ;)
