After seeing that people were liking the HTC keyboard better then the one that comes with the X10 I thought I would give it a try. I read through the threads and thought I understood the install process but I can't seem to get it to work. Here is what I did:
Down loaded the high-res version titled HTC_IME.APK to my computer.
Transfered the file to the root of my SD card,
Used file manager to find the file,
Selecting the file with file manager caused the file to install, there were no errors during the install.
I rebooted the phone and went to setting - locale & text and put a check mark beside Touch Keyboard
Opened my SMM and hard pressed the white text box near the flashing cursor.
This brought up an menu called Edit Text - Input Method
Selected Touch input.
At this point I get the following error - Sorry! The application Touch Input (process com.htc.android htcime) has stopped unexpectedly. Please try again. There is a Force Close button that clears the screen but the error comes back almost at once even though I'm not in an app that is calling the keyboard.
I have unselected the Touch key board and now all is well. Any thoughts as to what I did wrong?
Thanks
Thanks
I have updated the other thread to note that you need to have both although I am sure I have never actually run the installer on the clicker app. But anyway folks... follow the advice here and not your dumb phone guide.
