Root help with icons??
I know about go launcher, I got adw and I wanna keep the icons I have. just change the color of some of them. is there any way to edit the color with a image editor?
You can try to download a set of icons, edit them then put them on your sd then set the icons I've done that a few times with launcher pro
alrighty I downloaded metrostation icon pack from the market, not the same exact icons but at least I can change the color. thanks
alright now that i downloaded the icon pack, I changed the icons. and after about 5 minutes one icon changes back to the original. this has happend about 8 times and its starting to bug me, any fixes? the icon that keeps reverting back to original is the app drawer icon in the dock.
