Apps Help with implemented AdMob Android without XML
Canvas
Hey there people,
I have a massive question to ask as I am really stuck on this and it would be create to get ads on my free application, ok first off I have been following this book
Beginning Android games 2011
Beginning Android Games
Now this book implements a very nice and simple game framework which I use (a simpler version can be found here
Day 5: The Android Game Framework: Part I - Kilobolt
Now this framework doesn't use any type of XML file what so ever, it uses a framebuffer to draw things onto the screen. now when the application is first started, this is the first method called which is in the AndroidGame.java
[HIGH]
@Override
public void onCreate(Bundle savedInstanceState) {
requestWindowFeature(Window.FEATURE_NO_TITLE);
getWindow().setFlags(WindowManager.LayoutParams.FLAG_FULLSCREEN,
WindowManager.LayoutParams.FLAG_FULLSCREEN);
boolean isPortrait = getResources().getConfiguration().orientation == Configuration.ORIENTATION_PORTRAIT;
int frameBufferWidth = isPortrait ? 480: 800;
int frameBufferHeight = isPortrait ? 800: 480;
Bitmap frameBuffer = Bitmap.createBitmap(frameBufferWidth,
frameBufferHeight, Config.RGB_565);
float scaleX = (float) frameBufferWidth
/ getWindowManager().getDefaultDisplay().getWidth();
float scaleY = (float) frameBufferHeight
/ getWindowManager().getDefaultDisplay().getHeight();
renderView = new AndroidFastRenderView(this, frameBuffer);
graphics = new AndroidGraphics(getAssets(), frameBuffer);
fileIO = new AndroidFileIO(this);
audio = new AndroidAudio(this);
input = new AndroidInput(this, renderView, scaleX, scaleY);
screen = getInitScreen();
setContentView(renderView);
PowerManager powerManager = (PowerManager) getSystemService(Context.POWER_SERVICE);
wakeLock = powerManager.newWakeLock(PowerManager.FULL_WAKE_LOCK, "MyGame");
Where in here could i try and implement the admob banner? Also this is what a screen class looks like
public LogoScreen(Game game)
super(game);
@Override
public void update(float deltaTime)
Graphics g = game.getGraphics();
List<TouchEvent> touchEvents = game.getInput().getTouchEvents();
int len = touchEvents.size();
for(int i = 0; i < len; i ++)
try
TouchEvent event = (TouchEvent) touchEvents.get(i);
if(event.type == TouchEvent.TOUCH_DOWN)
game.setScreen(new MainMenuScreen(game));
catch(IndexOutOfBoundsException io)
@Override
public void paint(float deltaTime)
g.drawImage(Assets.logoScreen, 0, 0);
@Override
public void pause() {
// TODO Auto-generated method stub
@Override
public void resume() {
@Override
public void dispose() {
@Override
public void backButton()
android.os.Process.killProcess(android.os.Process.myPid());
}[/HIGH]
If I wanted to display an admob advert in the logoScreen what could i do that would work? I am really confused on how I can implement admob into my application, if any one can shine some light on this or help me that would be great :)
Thank you
Canvas
ohh also
Here is the code for the FastRenderView
[HIGH]package com.CC.framework.implementation;
//Imports
import android.graphics.Bitmap;
import android.graphics.Canvas;
import android.graphics.Rect;
import android.view.SurfaceHolder;
import android.view.SurfaceView;
public class AndroidFastRenderView extends SurfaceView implements Runnable
//Variables
AndroidGame game;
Bitmap framebuffer;
Thread renderThread = null;
SurfaceHolder holder;
volatile boolean running = false;
public AndroidFastRenderView(AndroidGame game, Bitmap framebuffer)
super(game);
this.game = game;
this.framebuffer = framebuffer;
this.holder = getHolder();
running = true;
renderThread = new Thread(this);
renderThread.start();
public void run()
Rect dstRect = new Rect();
long startTime = System.nanoTime();
while(running)
if(!holder.getSurface().isValid())
continue;
float deltaTime = (System.nanoTime() - startTime) / 10000000.000f;
if (deltaTime > 3.15)
deltaTime = (float) 3.15;
game.getCurrentScreen().update(deltaTime);
game.getCurrentScreen().paint(deltaTime);
Canvas canvas = holder.lockCanvas();
canvas.getClipBounds(dstRect);
canvas.drawBitmap(framebuffer, null, dstRect, null);
holder.unlockCanvasAndPost(canvas);
public void pause()
running = false;
while(true)
try
renderThread.join();
break;
catch (InterruptedException e)
// retry
}[/HIGH]
