Root Help with ini.10.rc
Krlypumaa
Android Expert
hi evry1... im trying to edit the ini.10.rc script.. and make it stick. w/out getting back to default.. i noticed that we can edit (tweak) the brightness of screen and the LTE data values from there... same in ini.rc .. so instead of editing the buildi.prop for that. had a post from a linux tech-Dev. of redhat... but i lost it. can anyone help. if i learn how to do it im gonna start wrking in this motion, F3 of wife n a F6 the i bought.. before connecting f6 n leaving motion a side...
i notice few ppl hav seen my post.. but where are u super devs... saaaaaammmyyyyy .PeeeeeGeeeee,
SheeeeebAnggggg.. Jonnnnnneeeeeee,Swaaaaainnnn,Rihhhhnnnnnooooo.. Demmmmmon...shut is any of you hereeeee...
some of these have copies elsewhere and are linked. so modifications dont stick.
you maybe able add a setprop line to init.d . or i would think you can just add the "setprop" line to the qcom postboot file. though you may have to have a line setting permissions first so your command is accepted
shuut.. thats why its not sticking n yes i notice that init.10 rc run first and then init.rc...i thought it was more simple.. that link of the dev i talked about.. he gives some way to wrk with it .. but i lost link.. i guess i will hav2 figure out.. thnx for reply.. Rhino... i will need your help later. with the F6 to mount external sd. can i bother you with that later..
Check you're browser's history, the link should be there. You can see links going way back. It's how I find old links sometimes when I lose them.
thnx. for head's up.. but i erased off 1 of my computers that had xp and upgraded software.. to 7 that pc was to wrk with old stuff and break softs.. U know (Guinea pig).. so totally lost it.
wondering if you found out how to do this.
there are alot of services i would like to disable amongst these files
