Help help with keepass sonyx10
jack frost
So I downloaded keepass for my PC and then downloaded keepass for my x10 right. then I put all my passwords into the PC version and saved it. then I transferred the file I had made which was .kdbx
okay so here are my problems.
1) I can't figure out how to use keepass on the phone. is there a way to search for files to open? what about ways to delete files I don't want.
2) I can't find the file I put onto the phone. I'm kind of leaning towards assuming that the phone version may not be able to read the PC version of the file.
3) when I open keepass all I see is a .kdb file extension that I deleted manually using PC companion (it was the test file). why can I still see this file even though when I click it it says "file not found", and why can't I see anything else.
thanks for any help or advice you guys may have. this seems to be the last issue I can't figure out on my own using search.
