help with launchers
Env2
I just picked up my droid2 today and I like it for the most part. But I'm still sort of a droid noob. I downloaded awd launcher and I have no clue how to use it. Home switcher dosent work with froyo 2.2 help pleasee
The two best launchers are Launcher Pro and ADW...you should try both.
When you install a launcher, the first time you select the Home button a dialog should appear with a choice for which launcher to launch and an option to set it as default.
Install Launcher Pro and the choice screen should appear.
clear default is a free app that clears out your home launcher choice. then, when you press "home" it will prompt you for which home you want to chose with the option to make it your default.
