help!! with lgstylo 2 screen!!
my home screen isnt showing up, it shows a white screen that says "enter password to unlock" i have put my ode in numerous of times but it doesnt do anything i need answers please, i have tried turning it off and on, taking the battery out. and it started doing it this morning it was dead but when it came back on it showed the screen and i dont know what to do :( please help it would mean a lot to me
I would do a factory reset,
  1. Back up all data on the internal memory.
  2. Turn off the device.
  3. Press and hold the Power and Volume down buttons.
  4. When the LG logo appears, quickly release and then re-hold the Power button while continuing to hold theVolume down button. 'Factory data reset' appears.
  5. Use the Volume down button to highlight Yes.
  6. Press the Power button to confirm.
  7. Erase all user data and restore default settings' appears.
  8. Use the Volume down button to highlight Yes.
  9. Press the Power button to reset the device
when i hold down the power button and volume buttons it just shows power off or restart
