Help with Mantano reader
Sheerluck
Im having a problem with Mantano and I am wondering if anybody is experiencing it and or knows a fix for it. The problem is when I select a word, to be defined, with any of the web options ( google, wikipedia, wiktionary ) the second time I use it crashes. The first time I can scroll the screen up and down with no problems. The second time, when I try to scroll the screen, it crashes to a report screen. The embedded dictionary works with no problems but when I use any web options it will crash. I can make this problem happen every time so it isnt random. I have reported the problem to Mantano but havent heard from them and its been about a week. Not to mention Ive reported this problem before. I would appreciate any feedback from anyone. Thanks.
