Help Help with media playback.
xdbuix
I'm having trouble with media playback. Particularly, I'm trying to transfer my itunes library to my microsd card to put on the transformer. So far, I'm having no luck. I used doubletwist to put the music on. I've tried putting music directly on the card. The card's working fine and out of all the songs I put on, usually 10 work out of all of them. What's the easiest way to transfer music? Thanks! :o
drag and drop. don't use proprietary anything, especially if it has to do with apple. You can also try winamp. They have an android app and app for your pc.
Thanks I found out it was the Microsd card itself after using another old card. The whole time iw as thinking it was the actual transformer. Thanks!
