I'm about to flash over to the MIUI ROM and want to download and use the Concept ICS theme...but I'm confused as to how to install the theme. What do I do after I download the theme to my PC?
Thanks for your help guys! Unfortunately, I cannot get the MIUI ROM to install. When I begin installation, it aborts and says "install bad" or something like that.
Redownload..... Make sure it finishes / is not currupt
You could try to download the Evo 3D's version if your S-OFF and have the modified hboot
It installed fine this time but now it's stuck on the boot screen, the one that says MIUI.US United Worldwide. It's been on that screen about 10 minutes..
Pull the battery and boot it up again.
