I have tried all the roms and cant send pictures. The messaging just says sending but never does. I have installed a Boost fix but it didn't work either.
I.m sorry if I shouldn't have started a new thread but I am new to this.
By all the roms what do you mean. Because theres roms for B09 (ICS) and roms for B11(JB), Is your phone updated to the new JB B11 update that boost released? Or are you on teh stock ICS (B09)? If you didnt update and are still on B09 did you try flashing one of the B11 based roms? If so did you flash teh system prep zip before flashing. Becasue teh new update has new partitions that need to be flashed first before running a B11 based rom
Sounds like you didnt flash the system prep zip before flashing a b11 rom , atleast from what youve said so far. The jb update also had new partitions that needed to be flashed so the phone would work properly. These partitions are not included in the roms. Its a seperate flashable zip.
Same here can't get mms functioning, tried tweaking settings through nandroid manager etc.,
However I downloaded the SuperROM B11_2.zip file not the no bloat version So I'm going to reflash everything again I guess and will update!
Thanks
