That all depends on whether there are enough of your devices out there to justify the manufacturer's time and expense in sending out an OTA update. The more popular devices will most assuredly receive it once the device-specific bugs are worked out... less known devices may not see the update. I hope this helps.
I believe Intex are an Indian importer of budget tech products from China, from manufacturers unknown. So given that, not likely. Could be worth you checking with them though, and enquiring about it.
