help with my rooting s2?
Cloudff7
Hi can anyone help me with rooting my s2 i'm on 4.0.4 i9100bvlep and i'm also on orange bit of a newbie on the how to rooting my phone so can any one plz help me with what software not 100% on what to download.....
Hello and welcome to Android forums Cloudff7! :)
See the Rooting Galaxy S2 - Dummies Guide, posts #1, #2 and #3, for step-by-step instructions, with videos, for absolute beginners.
I strongly suggest reading, carefully and thoroughly, those 3 posts before attempting to root your phone.
p.s will it work on i9100b?
There is no model.. i9100b
Just read the opening few paragraphs of the Rooting Galaxy S2 - Dummies Guide to ascertain which model of phone you actually have.
This is a step-by-step guide for absolute beginners. Please read posts #1, #2 and #3 carefully and thoroughly as they will take you through the rooting procedure and answer your queries. Particularly post #3 as this has, "Tips for using this Dummies Guide".
This guide is for rooting the Samsung Galaxy S2, GT-i9100, GT-i9100M, GT-i9100T & GT-i9100P only and no other variant.***
If you are unsure of the model of your phone, go to Settings > About phone > Model number
#1.2. Is it difficult
That really depends on your ability to read and follow instructions. I would strongly suggest that you read all the links published here, carefully and thoroughly, to help you understand the process before attempting to root your phone. The actual, "flashing", process, post #2, takes about 30 seconds, however, the set-up for this is longer and can be done in advance.
