Help Help with "My Verizon" app
VinniePaz
Yea so basically when I open the "My Verizon" app, I get a message saying, "This application requires the Verizon Login Client. Please download the login Client and start the application again. error code - 205"
Where do I get this?
I believe if u are rooted, you will get this error message.
So only solution is to un root. Cause fr what I read, this requires some type of Verizon verification and that requires a non rooted phone.
There's a VZW login client in the Market you can download.
I'm running Gummy and I had to, to get NFL mobile to work...
NOTE: You have to be on VZW network to login! you can't be on WiFi(at least the first time). If you look at comments on the app a lot of them say it doesn't work, but I bet they were on WiFi when they tried...
OK I uninstall and reinstalled, tried over 4G and downloaded the newest version and still get the same message. So the exact name is Verizon client login I should download, because where I can't seem to find it.
Edit - finally found it and it works. Thanks guys
