About 3 months ago I got my San Fran and I rooted, added a custom ROM etc all fine, but a couple of days ago I updated some apps on my phone and installed BusyBox using the most popular installer on the market in the hope that it will update my SuperUser as the SuperUser update fixer wasn't working but then I rebooted my phone and it never turned on, it just stayed on the green bot
I've heard that if it stays on the green bot it means it's bricked? Is this correct?
I've posted at MoDaCo but I haven't got a reply yet and I'm pretty desperate. I can't remember anything about anything when it comes to flashing and everything else. Do I need to reflash it and install the stock ROM? Or is there something else I can do? I can't remember what GEN my phone is but I can get into Clockwork Recovery. I've wiped my phone, cleared the cache and reset it to factory default but still nothing will work.
I'm pretty worried and I really would appreciate some help as I don't really know what I've done for it to be this way :/. Please be slow with me too, I have forgotten just about everything and I'm worried to buck anything up even further.
I've heard that if it stays on the green bot it means it's bricked? Is this correct?I've posted at MoDaCo but I haven't got a reply yet and I'm pretty desperate. I can't remember anything about anything when it comes to flashing and everything else. Do I need to reflash it and install the stock ROM? Or is there something else I can do? I can't remember what GEN my phone is but I can get into Clockwork Recovery. I've wiped my phone, cleared the cache and reset it to factory default but still nothing will work.
By no means am I having a go, just posting so that others reading can make an informed choice as to whether to backup right this instance, as losing everything is a real pita.
