Help with phone storage!
Aloha Kat
Hey guys,
I really need some help transferring my apps and texting to my new sd card but my phone, when i go into settings/applications, does not give me the option to transfer anything to the sd card.. please help!
Hello and welcome aboard. I don't know what device you have, but hopefully the below steps will work for you.
Thanks for stopping by to join us. Good luck. シ
Go into Settings ---> Applications ---> Manage Applications and wait for this list to be populated with not just the applications but the amount of memory they are using up. Select a larger app and on the next screen if the the app can be moved to the SD card you'll be able to push the Move to SD button. Repeat the process for each app.
