I running this: http://forum.xda-developers.com/showthread.php?t=1899085 (Rage AOSP) and I was screwing around with Propmodder to get a theme to load. I searched a compiling error in one of the themes, it said to reduce the pixel to 140. The theme worked but Prop modder, file explorer and others refused to open back up. Did a couple factory reset and got it close using build.prop modifier. Whats the correct pixel density for the Rezound? Prop modder now says it is not compatible with my device now in google play store. I'm a NOOB.
