Help Help with Razr
Don Webb
I use the button on the side to put my phone in sleep. Is there anyway to get rid of the lock screen? It is a pain while driving.
I myself am running the "unofficial" leak of ICS but I'm pretty sure that you can just choose menu>settings>security>lock screen and then choose NONE....Hope this helps
I don't think you need to reboot in order for it to change...you can try but I am 99% sure it won't change anything....Good thing though that the Android 4.0 update will be coming within a week or so and I know ICS you can change the lock screen to none......Just pay attention to any over the air update that pops up on your screen.
