help with reactivating a flashed evo3d
GotMelon
Hi i bought an evo 3d that was flashed over to boost, it has the pervious owners account on it so i confirmed it is a boost mobile account. problem is that when i go to about phone, phone identity i try to use the meid listed there, boost says it's invalid, not anuff digits, i tried useing the msl app i saw in the tread http://androidforums.com/boost-mobile/646633-reactivating-flashed-phone.html
but the phone is not rooted and said it needs to be to use that app.
If your looking at the MEID in the about phone menu you can input that into
android - whiterabbit.org
and it will tell you the esn you need to put into boosts website, though I thought you could put the meid into the boost website too. I will check on that.
You can also dial ##msl# and then enter all zeros for both mdn/msid. That will reboot the phone and make it reboot into ota. This will probably only work once or twice before the profile 0 password goes corrupt.
