Root Help with root
Its a well documented problem that since asa14 the original motofail2go exploit no longer works. The phone has also always had an issue with holding a custom recovery that was flashed to it via adb. For this phone id recommend getting TWRP 2.5 and flashing that via adb and then catching it before the main system boots thereby preserving the custom recovery. From there you can root and boot into the main OS and use an app to flash your prefered custom recovery.
Hope this helps.
CMNDR
