Root Help with Rooting i897
lunatic59
Moderati ergo sum
Moderator
A member asked for a little hand-holding with rooting so we are bringing it to a new thread.
Here's the beginning:
First you will need to download a few things:
You'll need to have the drivers installed so you'll have to install Kies Mini if you haven't already.
Next you'll need Odin3 and the CornKernel to root. Links can be found here: http://androidforums.com/captivate-all-things-root/493850-guide-rooting-adding-cwm-recovery-2-3-5-corn-kernel-2.html.
Finally you'll need an ICS rom. I'd recommend this one for now http://androidforums.com/captivate-all-things-root/505142-guide-install-ics-4-0-3-docs-master-ics.html
You don't need to do anything yet, just get the files downloaded and saved to a folder so you can find them.
Feel free to chime in or follow along.
No. What we will do first is root your phone and install CWM (Clockworkmod) recovery so you can perform a nandroid backup. A nandroid will make a complete image of your phone as it is setup now in case anything goes wrong with flashing it (unlikely), we can return it to this point rather than reflashing stock and setting you back to square one.
did the root and added CWM. That is all I have done so far because the link said
*Avoid using Nandroid as some roms will brick your phone if you try to use it, do the research*
Waiting on you for next move
Jeff
As far so know the only issue is ROM manager, which will corrupt some CWM installations on Samsung phones. Let me do some checking.
I didn't find anything about Nandroid Bricking the Captivate. Could you post the link to where you found it?
Oh, you know I just ignored that. :o
I think the warning is there for using nandroid after you've flashed a custom rom, although I've never actually seem any Captivates bricked by nandroid. If you go to menu>settings>about phone what is your kernel version now?
sorry for the long spaces between posts. I got called in to supervise a fiber optic installation that wasn't going well. Anyway, I would recommend performing a nandroid before we flash. You will also want to make copies of all your personal files and media on the phone, both from the internal memory and any external sd cards. Finally, if you haven't got your contacts sync'ed to Google, you'll need to back them up. And if you have test messages you'll want to keep, then you need to back them up as well.
No problem, I am on your time on this one. You are helping me out big time.
I think I have done nandroid backup, sitting tight until further notice:smokingsomb:
To check if you do in fact have a nandroid backup, you should look in your /sdcard partition and see if /clockworkmod/backup/(date of backup)/ exists. You might want to copy the contents off this folder as a belt and suspenders kind of precaution. Speaking of backup, if you've copied all the data off the phone that you wish to protect, then we are ready to flash.
This should take 20-30 minutes depending on how quickly you execute the steps.
First thing you want to do is make sure the phone is fully charged since this is all done with the phone unplugged. Nothing will brick a phone faster than dying in the middle of a flash.
Now, ready? Take a deep breath ... take another ... don't hyperventilate.
Copy the rom file (keep it zipped, do not expand the files) to the root of your internal SD card partition. Yours will be something like "Doc's_Master_ICS_Rom_V3.1_by_VibranTurk-Cappy.zip" and should be around 133MB.
Boot into Clockworkmod Recovery. Shut down the phone. Pull the battery for a second or two, remove the exrternal sd card if there is one, and the sim. Put the battery back and close 'er up. Press and hold the vol up and the vol down buttons then press and hold power. The second time the screen flashes the splash screen, release the power button but keep holding the volume buttons. Once you get the recovery screen, release the vol. buttons.
Use the vol. up and down keys to select the options and use the power button to confirm your selection.
Select wipe data/factory reset. This will remove your personal data and put the phone in a clean state. It is important to do this when flashing any rom. When that option is highlighted, press power to select. You'll have to scoll again to the confirmation and press power again. This operation is pretty quick. When done, press the back button as many times as necessary to get to the main CWM screen.
Clear the caches. Some say this is optional for roms, but because this rom includes a new kernel too, I always do this. Same method ... highlight wipe cache partition. Press power to select. Scroll to confirmation and press power again to wipe. Then back to the main CWM screen. You should also wipe the Dalvik cache at this point. If it's not in the main cache wipe options, it will be under advanced.
Install ZIP from SD card. Highlight and press power to select. Scroll to the rom zip file which will be pretty far down if you have a lot of folders on your sd card. when you have that highlighted, press power to select and again confirm as before. Now you are installing the rom. This takes a while as it flashes a new modem, new kernel and then installs the rom. Let it run and be patient. A couple of times it may appear to stall for as long as several minutes, but that's normal, just let it go and don't panic and restart the phone until it tells you it's done. When it is done, go back to the main CWM screen and reboot. The first time it boots it sits on the splash screen a while while it builds the files, so again, be patient.
Congrats, you are now on ICS. :D
Nothing there. When I try to back up it starts, phone goes blank, then after 15 mins or so I pull battery to get back to try again?
Just to be clear, you are booting into CWM and choosing the backup and restore option? When you boot into CWM it should tell you the version you are using. Let me know.
Wow, that was simple enough. It installed rom and booted itself in about 5 mins?
lunatic59 Thanks you for taking time to help a complete noob with this. If I had know it was that easy, I would have done it a looong time ago.
Thanks again,
Jeff
lunatic59 Thanks you for taking time to help a complete noob with this. If I had know it was that easy,I would have done it a looong time ago.
Thanks again,
Jeff
That's going on your rom-flashing t-shirt. :D
