Root help with rooting
greg1956
I have a droid bionic running 4.1.2 on 98.72.22.XT875 was wondering if I do factory rest
Will go back to orginal version so I can root it there seems not be a easy way to root this version at this time is that right,
Thanks
No. A FDR will only remove any personal user data/apps from the phone, it will not change the version of Android on the phone.
You will end up with a clean install of 4.1.2.
Because of the locked bootloader, there is no way to move back to a previous version of Android.
