Root help with s2e
hd1148
for starters i am super new to all of this and have no idea how to even make calls half the time....so patience please!
i started running out of room on my prevail so i decided to partition and use s2e to free up space.
i backed up everything and use cwm to partition my sd card.
clean and wipe internal memory
flash cm7 and start up
download s2e and go through the steps (go to advanced, click ext4/import)
i then reboot into cwm and flash cm7 again and reboot.
here is the problem...it will reboot and 'android' will flash across the screen. then.....nothing. it will stay there for a good 15 minutes then the screen goes black. i reboot and it starts, but now s2e is gone and so is market.
i have tried this process again/wiped and reflashed/repartitioned/stood on my head/done a rain dance. nothing worked.
please someone help!!!! it would be greatly appreciated.
If you flash the mapsfix-ext kernel or katokernel for cm7 you don't need s2e. It does it automatically AS LONG AS YOUR SDCARD IS PARTITIONED.
No setup needed
No setup needed
:D....that's awesome. i checked my internal memory and sure enough saw the extra space. thanks for pointing me in the right direction.
