ImonAndroidNow
I was just wondering how long the battery should last for this device. When I look at battery usage, I don't get why it says my device has been active for 22 hours since my last full charge, and that it says my SCREEN has used 50% of my battery, though it has only been on for 5 hrs. Last time I checked, 50% of 22hrs was 11hrs, not 5hrs.
And through combined usage of my applications, I had had only used 68% of my batttery (which was something like 7 hrs), was the other 32% used through my Tab A just sitting on my shelf in it's rest mode thing (where the screen goes black and it seemingly turns off, but still uses battery at a slower rate. I don't know the formal term for this feature).
Can someone, I guess... explain how the battery menu works, I'm confused as heck. Thanks in advance.
Edit: What does device idle mean. Is it when the screen has timed out (
I think that's the formal name for the rest mode like feature), or just when you leave the screen on when your watching youtube or Netflix, or maybe reading a news article (basically you not touching the screen)?
Also, my device tells me Youtube has only contributed to 2% of my battery use, even though it's basically the only app I use... Whaaaaaaa?! Again, thanks in advance for any answers.
One more question, how many minutes is one percent worth for this kind of tablet, the 8 inch model, that is, NOT the 9 inch model. Thanks in advance...
