Hi guys,
I'm developing an app that via bluetooth controls few parameters of an external hardware.
To set this parameters, I've created a custom preference screen. When entering to the preference screen, 3 parameters are displayed, and to control these, I use a dialog preference that displays a seekbar, to select a value in a range from 0 to 100.
The problem is that, If I only use this custom preference screen with 1 parameter, it works fine, but when I enable the 3 parameters in the custom preference screen, the app crashes.
The code is the following:
Preferences.java
[HIGH]
public class Preferencias extends PreferenceActivity {
@Override
addPreferencesFromResource(R.xml.preferencias);
}[/HIGH]
SeekBarDialogPreference.java
[HIGH]public class SeekBarDialogPreference extends DialogPreference
private static final int DEFAULT_MIN_PROGRESS = 0;
private static final int DEFAULT_MAX_PROGRESS = 100;
private static final int DEFAULT_PROGRESS = 0;
private int mMinProgress;
private int mMaxProgress;
private int mProgress;
private CharSequence mProgressTextSuffix;
private TextView mProgressText;
private SeekBar mSeekBar;
public SeekBarDialogPreference(Context context)
this(context, null);
public SeekBarDialogPreference(Context context, AttributeSet attrs)
super(context, attrs);
// get attributes specified in XML
TypedArray a = context.getTheme().obtainStyledAttributes(attrs, R.styleable.SeekBarDialogPreference, 0, 0);
try
setMinProgress(a.getInteger(R.styleable.SeekBarDialogPreference_min, DEFAULT_MIN_PROGRESS));
setMaxProgress(a.getInteger(R.styleable.SeekBarDialogPreference_android_max, DEFAULT_MAX_PROGRESS));
setProgressTextSuffix(a.getString(R.styleable.SeekBarDialogPreference_progressTextSuffix));
finally
a.recycle();
// set layout
setDialogLayoutResource(R.layout.preference_seek_bar_dialog);
setPositiveButtonText(android.R.string.ok);
setNegativeButtonText(android.R.string.cancel);
setDialogIcon(null);
@Override
protected void onSetInitialValue(boolean restore, Object defaultValue)
setProgress(restore ? getPersistedInt(DEFAULT_PROGRESS) : (Integer) defaultValue);
@Override
protected Object onGetDefaultValue(TypedArray a, int index)
return a.getInt(index, DEFAULT_PROGRESS);
@Override
protected void onBindDialogView(View view)
super.onBindDialogView(view);
TextView dialogMessageText = (TextView) view.findViewById(R.id.text_dialog_message);
dialogMessageText.setText(getDialogMessage());
mProgressText = (TextView) view.findViewById(R.id.text_progress);
mSeekBar = (SeekBar) view.findViewById(R.id.seek_bar);
mSeekBar.setOnSeekBarChangeListener(new OnSeekBarChangeListener()
@Override
public void onStopTrackingTouch(SeekBar seekBar)
@Override
public void onStartTrackingTouch(SeekBar seekBar)
@Override
public void onProgressChanged(SeekBar seekBar, int progress, boolean fromUser)
// update text that displays the current SeekBar progress value
// note: this does not persist the progress value. that is only ever done in setProgress()
String progressStr = String.valueOf(progress + mMinProgress);
mProgressText.setText(mProgressTextSuffix == null ? progressStr : progressStr.concat(mProgressTextSuffix.toString()));
mSeekBar.setMax(mMaxProgress - mMinProgress);
mSeekBar.setProgress(mProgress - mMinProgress);
public int getMinProgress()
return mMinProgress;
public void setMinProgress(int minProgress)
mMinProgress = minProgress;
setProgress(Math.max(mProgress, mMinProgress));
public int getMaxProgress()
return mMaxProgress;
public void setMaxProgress(int maxProgress)
mMaxProgress = maxProgress;
setProgress(Math.min(mProgress, mMaxProgress));
public int getProgress()
return mProgress;
public void setProgress(int progress)
progress = Math.max(Math.min(progress, mMaxProgress), mMinProgress);
if (progress != mProgress)
mProgress = progress;
persistInt(progress);
notifyChanged();
public CharSequence getProgressTextSuffix()
return mProgressTextSuffix;
public void setProgressTextSuffix(CharSequence progressTextSuffix)
mProgressTextSuffix = progressTextSuffix;
@Override
protected void onDialogClosed(boolean positiveResult)
super.onDialogClosed(positiveResult);
// when the user selects "OK", persist the new value
if (positiveResult)
int seekBarProgress = mSeekBar.getProgress() + mMinProgress;
if (callChangeListener(seekBarProgress))
setProgress(seekBarProgress);
@Override
protected Parcelable onSaveInstanceState()
// save the instance state so that it will survive screen orientation changes and other events that may temporarily destroy it
final Parcelable superState = super.onSaveInstanceState();
// set the state's value with the class member that holds current setting value
final SavedState myState = new SavedState(superState);
myState.minProgress = getMinProgress();
myState.maxProgress = getMaxProgress();
myState.progress = getProgress();
return myState;
@Override
protected void onRestoreInstanceState(Parcelable state)
// check whether we saved the state in onSaveInstanceState()
if (state == null || !state.getClass().equals(SavedState.class))
// didn't save the state, so call superclass
super.onRestoreInstanceState(state);
return;
// restore the state
SavedState myState = (SavedState) state;
setMinProgress(myState.minProgress);
setMaxProgress(myState.maxProgress);
setProgress(myState.progress);
super.onRestoreInstanceState(myState.getSuperState());
private static class SavedState extends BaseSavedState
int minProgress;
int maxProgress;
int progress;
public SavedState(Parcelable superState)
super(superState);
public SavedState(Parcel source)
super(source);
minProgress = source.readInt();
maxProgress = source.readInt();
progress = source.readInt();
@Override
public void writeToParcel(Parcel dest, int flags)
super.writeToParcel(dest, flags);
dest.writeInt(minProgress);
dest.writeInt(maxProgress);
dest.writeInt(progress);
@SuppressWarnings("unused")
public static final Parcelable.Creator<SavedState> CREATOR = new Parcelable.Creator<SavedState>()
@Override
public SavedState createFromParcel(Parcel in)
return new SavedState(in);
@Override
public SavedState[] newArray(int size)
return new SavedState[size];
}[/HIGH]
preference_seek_bar_dialog.xml
[HIGH]<LinearLayout
xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:tools="http://schemas.android.com/tools"
android:layout_height="match_parent"
android
rientation="vertical" >
<TextView
android:id="@+id/text_dialog_message"
android:layout_height="wrap_content"
android:layout_marginTop="6dip"
android
addingLeft="12dip"
android
addingRight="12dip" >
</TextView>
<TextView
android:id="@+id/text_progress"
android:gravity="center_horizontal" >
</TextView>
<SeekBar
android:id="@+id/seek_bar"
android:layout_marginBottom="6dip"
android:layout_marginTop="6dip" />
</LinearLayout>[/HIGH]
Preferences.xml
[HIGH]<PreferenceScreen
android:key="preferencias_principal"
xmlns:custom="http://schemas.android.com/apk/res-auto" >
<.....SeekBarDialogPreference
android:key="fast"
android:title="@string/listtittle1"
android:summary="@string/summary1"
android:defaultValue="40"
android:dialogMessage="Please select a value:"
android:max="100"
custom
rogressTextSuffix="%"
custom:min="0" />
android:key="climb"
android:title="@string/listtittle2"
android:summary="@string/summary2"
android:defaultValue="80"
android:max="100"
custom
custom:min="0" />
<....SeekBarDialogPreference
android:key="platform"
android:title="@string/listtittle3"
android:summary="@string/summary3"
android:defaultValue="60"
android:max="100"
custom
custom:min="0" />
</PreferenceScreen>[/HIGH]
Preferences.java
[HIGH]
@Override
}[/HIGH]
try
finally
a.recycle();
// set layout
@Override
@Override
@Override
@Override
@Override
@Override
return mProgress;
notifyChanged();
@Override
if (positiveResult)
@Override
return myState;
@Override
return;
int minProgress;
int maxProgress;
int progress;
super(superState);
super(source);
@Override
@Override
@Override
}[/HIGH]
[HIGH]<LinearLayout
android
rientation="vertical" ><TextView
android
addingLeft="12dip"android
addingRight="12dip" ></TextView>
<TextView
</TextView>
<SeekBar
Preferences.xml
android:key="fast"
android:max="100"
custom
rogressTextSuffix="%"custom:min="0" />
android:key="climb"
android:max="100"
custom
android:max="100"
custom
