JuanOrtiz210
The Rom works fine untill i go back to the backup of my nandroid and restore my data then all i get is a 20 reboots? Any help would be appreciated. Before i restore my data i get no reboots and dont have to slow down the cpu.
I would definitely suggest wiping cache/dalvik and fixing permissions.
i did
still just get reboots
How are you restoring your data? CWM? TiB?
I'm pretty sure this issue was discussed at some length in the rom thread. So I'd start reading backward from newest to oldest.
Ive have the same problem currently I gota ask does your phone give you an error message when you try to flash a new kernel if so im thinkin its the firmware currently im trying the unbrick method to reflash the stock firmware ill let you know if it works
