Help Help with SMS problem
megzy11
Hi!!!
I have received a txt message from a number already with an existing thread, however that one message does not appear anywhere in my inbox, and if i click on it in the notifications it just takes me to a blank create message. There is constantly the envelope at top and 1 next to the message icon but that one text is not there?? any ideas how to delete it or get it to appear in inbox??
i did search and try all the suggestions, i have searched the message in my inbox and it finds it but i cant delete it as when i click on it it takes me to a blank text?
when you open the blank message, in the options menu there, isn't there an option to delete the thread?
OR
instead of opening the message, long press the message and there should be an option to delete it
no there is only the option to discard the message, it just discards the blank message. And i can only see the message in the notifications bar if i hold that down nothing happens. The same thing happens when try an open txt as it would if i pressed 'new message'.:confused:
Hmmmmm, thats really weird, fortunately i never had this problem.
Well as a last resort i would suggest you to select delete all your inbox threads using the mark all threads feature(it'll include the troublesome message) if its feasible for you.
Also you should pm the guys in the thread i posted earlier, they would be able to help you better than me as they have experienced this problem.
good luck:)
