Help with SPB Shell 3D
Status
Not open for further replies.
avushkaa
Member
hi,
i had spb shell 3d launcher in my rooted SGSII.
i had to remove my microsd. but when i mounted sdcard and booted the phone it went into safe mode and spb shell was causing problems. so i uninstall and again tried to reinstall it. but it wont install saying not enough space to install.
previously i made it work with <removed>.
but it aint working now.
what should i do?
should i wipe /cache and /dalvik cache and try installing it again?
will that cause any prob to other sys things?
and my avast mobile security wont let me inside the app.it wants a 4-6 digit avast! password which i didn't set in with it. i tried 0000/123456 but no luck.i re-installed avast but again it wants password at the entry screen.
any suggestion? :help:
Sorry you are having issues, but the application you mentioned is specifically designed to bypass purchase verification and that is piracy. My recommendation is to buy a legitimate copy of SPB Shell and then get support from the developers if you need it.
Bypassing verifications to get paid apps for free is strictly against site rules.
*Thread Closed*
Status
