A
Android Question
Guest
I just downloaded terminal emulator but when I tried to type a command its screen disappeared. I tried again with no luck, even downsizing some apps to make room. What do I do now?
In fact the question wasn't mine, I posted the screenshot just to show how the terminal emulator app looks when everything is fine.From your screenshot, you're using the 'Terminal Emulator for Android' app.
https://play.google.com/store/apps/details?id=jackpal.androidterm
It appears you were able to enter the 'su' command and that took you to root prompt (going from $ to #). But with 'Terminal Emulator for Android' if I'm not mistaken that leading 'uo_a205@android' string before you had entered 'su' should have changed to something like 'root@xxxxx'.
Is that the point where your Terminal just quit? If yes, did you root your phone and what method did you use? And if you've got SuperSU installed, did you allow TEforA root privileges? Also, do you also have BusyBox installed?
