Help help with this tablet
  • Start date Start date
A
Android Question
Guest
i just got this tablet and it does not hold a charger for more that about 1/2 hour can anyone tell me if this is normal for this model or if i may have something turned on that is using way to much power? i got it from ebay and that may be the number one reason it is like this. although the person said i could send it back. anyway because i don't have much of my info on it i wonder if just resetting it back to the factory setting will help? also if i plug it into the laptop it says it is charging but it is not charging
this is the legal information if this helps
model number m94
android version 4.4.2
kernal version 3.4.0+ liuzi@gpt-server-sw #65 tue nov 18 12:57:36 cst 2014
build number full_gs702c-userdebug 4.4.2 kot49h eng.liuzi.20141118.130341 release-keys
i have no idea about that stuff but it may be important. also on this when i put a app on the desktop it goes out to the edges and i can't see them the screen shrinks and it expands so the apps disappear how do i get rid of that?
