I used this: http://thedroidguy.com/2013/07/how-to-unroot-samsung-galaxy-note-2-n7100-to-stock-firmware-67567
can you tell me please what to do to make my device not be rooted at all?
I think that what @Mikestony told you above re. Knox is the answer since the unroot thread you cited above purportedly flashes you back to stock firmware.
Flashing you back to stock would (or should) have removed any traces of root from your /system partition.
The bottom of that thread indicates you could email them with questions...not sure how useful that might be or how responsive they might be.
Yes Sir,that is correct.You could check the fuse by booting into download mode and checking the 0x0, or 0x1 bit.? @KOLIO --verify??
