Help with update and root files
derek10
I am wanting to update my phone to latest firmware and root it I am new at this but once something is explained I can usually do it. The thing is im a bit confused as to the files i need I have read A few posts on the subject some say use this file another that file or use odin and tick one package another says differentone post from Beerkan says to use JD1 then another says JH6. My phone's details are
Model---------------------- GT-I5700
Firmware Version------------2.1 update 1
Baseband-------------------I570EXXJC1
Kernal Version---------------2.6.29
root@SE-S611 #2
Build Number----------------ECLAIR.XXJCD
PDA------------------------I570EXXJCD
PHONE----------------------I570EXXJC1
CSC------------------------I570EH3GJC4
do I need boot files & phone files and pda csc files or do i just need JH6 the spica_JC3_ops file and LK2-o8_pda file.
Can someone please help and clarify whic files exactly and which options should be ticked in odin.
Thanks in advance
Well here i found some topics for you--:http://androidforums.com/htc-hero/8131-advantages-rooting-your-phone.html, http://androidforums.com/droid-all-things-root/128341-should-i-root-my-droid.html,and Android Search(rooting topic), Android Search(roms)you should look for how to root any android on YouTube.
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
Here are tuts for your phone-- : Rooting Your Phone<YouTube Guide on(How to root Android 2.1(Eclair))>
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
The Software Needed To Root<One Click Root>
