Hello,
I have looked at the related posts but they really didn't answer my particular issue. I had this version installed on my Dinc2 and it worked perfect. Now on my Galaxy S3 I cannot seem to get the same results.
All I want JD to do is to:
1. When I blank my screen or the screen times out and turns off (not using my phone), I want it to turn off Wifi and 3g/4g.
2. When I turn on my screen (Using my phone at home), to auto enable Wifi only but at the same time when I send pics/texts it should enable 3g/4g to allow that and then turn data off when pic or text is delivered keeping Wifi up the entire time.
3. When away from my house (WiFi), it should turn on 3g/4g.
I forgot to take the settings off the Dinc2 and use them in the Galaxy S3 before doing a factory reset (Selling the Dinc2).
Right now when I turn off screen, sometimes it turns both data/wifi off and sometimes Wifi remains on. Also sometimes when I turn screen back on both WiFi and data come on (Widget has both green lights on).
Also for some reason WiFi intermittently gets turned off and I have to go back in and turn it back on.
I am sure I have some settings wrong.. I am using the advanced profile. That I do remember from my previous phone. Also have Mobile Data, WiFi
enabled with auto disable, Autosync is ping.
Under Triggers, battery (5%) and screen enabled.
Any help getting the 3 items above to work on the Galaxy S3 would be greatly appreciated and please be specific with any options you may suggest.. Please don't assume I know JD well because like I said it has been awhile since I messed with it.
Thanks in advance
Thanks in advance
