Help help with wifi on zte warp
Ok i heard you could use the zte warp for wifi hotspot but i dont know how to do it. Does anyone know how??? Oh and how do you use its internet for game systems without a computer. Just the phones internet.
I have read that the Warp/BOOST will not allow it. I tried about every program out on every market....No success. Save yourself time. Move on to the next Warp adventure.;)
every tether iv used worked wel atleast he wifi ones used to barnacle ect
pdanet is a great usb tether its my only source o finternet i have downlloaded over 5 gb so far using the warp so it does work
After rooting the warp, I found that Foxfi freezes. Barnacle works for me, but not for all wifi devices, mainly ad hoc enabled devices. My XBox 360 will connect but its slow, but my Wii will not connect at all.
for me the best one is wifi tether i've tried in different phones, you have to be rooted but it worth it and is no big deal to root the warp, 15 mins if you do it well
You can use your phone for a wifi hotspot if your phone is rooted.
Remember with the new data restrictions, you'll be throttled real quick if you tether alot...
I'm unrooted-tired several apps-none worked on the warp-i followed all the instructions, read a dozen forums....I was able to use pdanet to Bluetooth tether my nexus tablet to the warp, tho - since I'm not a gamer, the speed has been fine so far
I was never able to successfully use wifi tether while unrooted. not sure if theres something current im unaware of though.
