Help with wifi profiles
I am trying out some tests I have geofences set for half of my work so I can enter and exit geofences...
When I enter I should a beep when I exit I should get 2 beeps
When I enter nothing happens.... If I open AutoLocation select work map comes up and I get 1 beep same for exiting... Radius is 500 meters ... I should not have open auto location for it to work
That's because Autolocation uses GPS to locate you accurately when showing you that map.
The phone then 'realises' where you are and the profile is activated.
I'm starting to wonder if we are hitting some hardware limitations as this is the only difference between our setups. The geofences are very reliable on my device and I very rarely get 2 active geofences at the same time, for example.
Maybe try having a shortcut on your Home screen to a reset task (if not already done). The same reset task that you added when both your geofences are active.
See if at least that solves the problem on the spot without having to go in Autolocation or Tasker, while we're thinking about a better solution.
I hit GPS icon on map but nothing happened any way
This am I lost WiFi and at home
Went into AutoLocation geofence monitor was stopped... I restarted it got WiFi for 1 second in status bar and it went away restarted it and this was a continuous loop... On the map I had a blue dot....
I have wondered if my phone is the issue for a long time when it was updated to Kit Kat I had to do a factory reset I am very unhappy with my phone but until March I am stuck...
In your opinion what should my next phone be
I wonder... If I Uninstall everything pertaining to tasker then Uninstall tasker reinstall everything then install version 1 to solve some issues
On a side note
Is there anything I can do with my phone to help our issues... I think I can get an app hold on a min
Just some thoughts
Forget about that other app, it's fake (see near the end in the description).
As for adding a shortcut, you need to go to Preferences> Misc > Allow external access
Sorry for not mentioning that.
What phone u have.... Would my carrier make a difference... I don't think my carrier would matter but just want to cover all bases
When I try to post pic using Tapatalk interface I slect icon on left window shows up it asks : do I want to use previous draft or start new no matter what I pick I get nothing
