Help with wifi profiles
I know this is probably not true but I wonder if it allows u to use root features one time.... If u delete your tasker profile/task feature no longer works
With help from you tube.....
Created a profile to open Apps with auto voice / auto launch
Works perfectly....
Accidently deleted it
Re created it 5 times can't get it to work like it did the first time when I created it
Depending on which superuser implementation you're using (Koush's Superuser or Chainfire's SuperSU), you may need to select an option to always grant access to certain applications.
Works perfectly....
If you could share a link to the tutorial as well as screenshots / exports of your profile we may be able to help you debug. :thumbup:
Come to think of it...... I Remember hearing in the video I had to subscribe to beta apps for this to work.... Is this what u mean
Without knowing which tutorial you were looking at (*hint hint*) I can't really say. It could be that you have to be using a beta version of Tasker or AutoVoice to do whatever-it-is-that-you're-after.
Video
Write profile as prescribed
Set behivor
Set command filter
Use regix
Hit back
New task
Select plug in
Etc
Hit home
Slide up black window pops up "auto voice is listening i say open camera and.................... . ..... Ready.. Nothing opens😈
Could my phone be out of memory / which is why tasker is not working properly
are you getting any error messages to indicate that? Android is usually pretty naggy with persistent notifications when the available storage starts to get low.
Also, sorry I kind of abandoned you. Had a bit of a crisis come up at work yesterday and I've been fighting with that nearly nonstop. Keep posting here though and hopefully some other folks can assist.
Are you still having issues with your WiFi-on-at-home/off-at-work?
Does Autolocation work for you?
If it does, I'm happy to share a few of my profiles to set up connectivity depending on location and time of day.
I use AutoLocation so you need to check if it's compatible with your phone and if you're happy to buy it. Otherwise there's going to be some rewriting to do...
