You should be able to just hold down the icon that you want moved. Depending on what launcher you have you might have to look in the launcher settings and unlock the dock first.I have used every possible search in forums and google to figure this out. No luck.
The bottom of screen shows Phone Messaging and Applications. I was trying to drag something to trash and it ended up in that bottom area. How do I remove it?
Thanks,
cj
I can move around applications above but not any of the four at bottom. It must be the stock launcher. Holding an icon doesn't do anything and I don't see any kind of menu for settings. This is my first smart phone so my general knowledge is very limited.
you're welcomethat's it!! thanks so much.
