kbrn
I re-flashed my phone and I was applied the update zip (joeys)
I choose to replace the you tube app with the HQ app but after applying the zip update the you tube app dissapeared then I tried installing the app manually with astro and it couldn't ..
So my question is how can I install it?
Almost forgot I also tried using root explorer with no luck
