Help! Your device isn't compatible with this version??
mick3y
I've got two identical phones (Sony Ericsson Xperia Ray), bought at the same time, with the same software version. I've been installing the same apps to both, no problems until recently..
Now on the one phone, I can't install or update anything, because 'Your device isn't compatible with this version'.. :mad: Any ideas?? :confused:
I've already tried deleting updates and cache from Google Play, but this only resulted in replacing Google Play with Market..
Thx in advance..
If you give it a bit, the Market should re-update to Google Play. I've had that issue before with a device, but it was running a custom ROM and a factory reset fixed it. Never seen your issue before, but I'd see if re-updating to Play Store fixes it.
