Help
Is there any way to fix the oem unlock on a galaxy a11 sm-s115dl
fix? like unlock? nope as of right now. you picked a sammy with snapdragon. they will always have a locked bootloader. gonna have to wait for the devs to figure a way around it. but it might be awhile as there is no forum over at https://forum.xda-developers.com/ for your phone, which means that there are no current developers working on it right now.
edit: next time pick a sammy phone that has dev support and stay away from sammy's with snapdragon processors.
No im referring to the oem unlock. in developer options there isn't and oem unlock option.
Could be referring to carrier unlock rather than bootloader, need more info.
If you're looking to unlock it from your carrier to use on a different one, that would have to be done by the existing carrier if you meet their requirements.
No oem unlock option in developer options.
That's difficult in the US isn't it? Unless one grey imports an international Exynos Sammy?
Same thing here in China, all Samsungs are Snapdragon. However FWIW my China variant Galaxy Note20 Ultra with Snapdragon does have OEM unlocking in the Developer options.
yes the US variant snapdragon sammy's will have the bootloader locked.
