Help Help.
hgrindle
For some reason this morning, I was on the menu thing (the bit where you touch the arrow button on the main screen) with all my apps up on show... but I must have touched something when i looked away because now, none of my apps are showing up when i go onto it... i have to find some other way of getting to them. The only ones that are showing up are Settings, App Sharing, Setup and a few others. But i just want to get all of my apps back onto one screeen?
Can anyone help?
Can anyone help?
Have you done a battery pull (remove battery to turn off and then turn back on)?
Moving to support forum
