You need to defrazzle the quid navigator function in your processor. That will fix the problem. If that doesn't work, then try lubricating the screen bearings and tightening the exhaust manifold under the battery. Let us know how it works out.
Are you using the correct type of unobtainium? Using the incorrect B-grade and not the correct A-grade, will cause problems, can void the warranty and may even cause an explosion.
not if you use the warp engine to create a time bubble... then force a negative-hyperphase by 180 degrees... which should put you back to before this shit started rebooting!
