Help Help
ChristiKate
I just switched from a Blackberry Curve to a Thunderbolt and I'm lost. The crappy book it came with barley explains anything and I was wondering if there was a better guide or videos someone can direct me to. Also, I hate that my phone automatically locks after a few minutes. Is there a way to turn it off? Thanks!
Hey...Don't worry; you'll get there. It just takes literally hours of playing with it (hopefully mostly FUN hours).
When you discover all that it's capable of, I think you'll be happy in the end.
With that said, do a Google search on "Android O/S Tips and Tricks"
Here's something to start you off with:
Master Google Android: 40 Tips and Tricks - PCWorld Business Center
Jumping from BlackBerry to Android? Here's what you need to know! | Android Central
From Blackberry to Android — Slaw
Good luck...and continue to use this forum as a resource; people are helpful here.
Just out of curiosity, where did u purchase ur phone?
To answer your question about your screen turning off - go to Settings -> Display -> Screen Timeout. Default is 1 minute.
