Help
CAubbibc2
Hi, I signed up because I thought it would be a good tool to use if I ever had any questions arise with my phone. I recently purchased the HTC ARIA, from AT&T. I like it a lot, but I'm currently having an issue. I have the settings on for vibrate, but when I receive a text message it doesn't vibrate. It doesn't do anything. It worked fine before, then just stopped working. If I change it to another setting, it works fine, just not for vibrate. I even went to the at&t store and asked the clerk and he said all my settings are correct, and to call at&t up and they could swap out my phone. I"m just checking here to see if anything comes up before I have to get a new one. Thank you.
Chris
Welcome to the Android Forums!
If you go into the Text Messaging app, you can hit the menu button and to go options. Here you'll find separate ringtone/vibrate settings for your text messages.
I know this is going to sound like a silly question but have you rebooted the phone lately? Sometimes phones/apps get weird and need a reboot to clean things up.
yep, i turned it off and on again, a couple of times. i appreciate the help but i think i need to call up and get a new phone. i hate getting a new phone, everythings gotta be a hassle.
I suspect that would be the prudent thing to do under the circumstances...
